How to install dlink shareport android app apk?
How to install dlink shareport android app apk? Is there a way that the android mobile phone can connect to the dlink router shareport? I hope there is a way that the mobile phone can access using the router which is dlink. I need your suggestion and answer regarding this issue and on how the setup being process.
Thank you.
