How to install downloaded korea pack font for Adobe Reader
Hello friends,
I downloaded korea pack font for Adobe Reader X and I need to have guide or steps in installing it into Windows platform? I will wait for your replies.
Thanks and cheers!
Hello friends,
Thanks and cheers!
I am going to give you some links, where you will get your desired "Korea pack font for Adobe Reader X".
It is Adobe Reader 10.0, File name- Adobe Reader X font packs- Korean, File size 5.86mb.
You will get free software from both of the sites.
I think you will be happy after getting it.
Hi,David Bailey,
Here you want to know how to install adobe reader x korea pack on windows platform.
I describe the installetion procedure in the below:
Thanks
