How to install the driver
There is always a problem with Windows 7 with Acer to install the drivers so its very easy to install the drivers in windows 7 you while you never mention about the windows version is that 64-b or 32-b well there are two ways to install the driver first of all go to https://www.acer.com/ac/en/US/content/home then click on download drivers and then click on 32 or 64 bit Acer and then give the model of laptop.
There you can easily find the driver version and then click on download there you will mention the path where you want to download after downloading you can run the exe file and driver will upgrade. While the other way is to purchase a CD of universal drivers and then install the driver.
Hi Azhar,
I guess your problem is how to install a driver. Well, in that case there are only a few ways on how you could be able to install your driver.
How to install?
1. Click the folder where the driver has been located.
2. Click the icon where you can see the word "INSTALL", then you will see a box where it needs your confirmation on whether you will install it in your hard disk.
3. Then click "YES".
4. Wait to load the system, and then follow the instruction.
5. Always click the continue or next option.
6. Then click "FINISH", after that you click the finish, your driver now is successfully installed.
How to Check if your driver is successfully installed?
1. Go to "START" menu.
2. Right click the "COMPUTER" or "MY COMPUTER".
3. Click "MANAGE".
4. Click "DEVICE MANAGER".
5. Find what driver did you install, if you can see a yellow icon beside the driver it means it didn't work, but if you can't see anything that means, the driver was successfully installed.
