I am using a Toshiba system with Windows XP. My system was infected with spyware which removed the drivers. I have removed the virus, but most of the driver seems to be missing. Please advice on where to have Driver Toshiba Finder and how to install the same, so that it will automatically update the missing drivers.
How to install Driver Toshiba Finder
You can install drivers from the official Toshiba website http://www.toshiba.eu/support/drivers/ but you have to be sure of the model.Otherwise, you can try installing third party software's that help you find the right drivers for your system.Checkout Driver Checker at https://driver-checker.en.softonic.com/
Once all the drivers are installed, please enable windows to install updates, all your drivers will be updated automatically.
Hope this helps.
To install Driver Finder, visit: http://driverfinderpro.com/support-drivers.php?id=toshiba
Visit Here.
Click Run (if you’re using Internet Explorer).
Click Save File (if you’re using Firefox).
Double-click DriverFinderSetup.exe to install.
Click Start Scan in Driver Finder™.
Download and install the latest Toshiba drivers recommended
You can also download the drivers direct from the manufactures; they are tested and up to date. You need the exact model number of your system then visit the hardware manufactures support website.
Locate the driver download area and choose the specific hardware you want drivers for.
Choose the drivers and download. Extract the downloaded drivers and update your device manager. More details of download and installation are given on the manufacturer’s website.
Thank you.
