Hello fellows,
How to install driver VGA Intel 3600 Windows XP? My Windows XP Operating System is working fine for almost one year and I never had any installation problem, but this time I need to know the proper way of installing driver VGA Intel 3600.
Regards, Charles Marry.
How to install driver vga intel 3600 Windows XP?
The standard VGA Driver is installed by default when you install Windows XP on your machine. So there is no specific way to install it separately. However if you have a corrupt driver ( While updating ) and one which you think has not been installed then go to Device manager and search for the device . Then right click and click on Update.
Thanks Hope it helped!
Dear Charles,
Thanks for sharing your problem with us.
Dear it is so easy to install any driver on your computer without the device's serial number and model number etc.
You have no need to get a CD of drivers.
Simply connect to the internet and visit this website.
https://www.driveridentifier.com/
This website provides software called "Driver Identifier" download it and install it.
It will scan your computer for drivers and after this process it will take you to drivers download page directly.
Download your drivers from that page, install it and enjoy.
It will fix your problem 100%.
Thanks
I assumed you are looking for VGA Controller Intel GMA 3600 Series drivers for Windows XP. I'm not sure if there is available drivers for Windows XP. For all I know, this comes with Windows 7 originally. But it would be best if you include the exact model name and number so we can identify if this is really the one you were looking for. Or you can also try to go to the Intel's website and then go to their download center and manually type the product name. You can find all the drivers that you need there or whatever is available for your device. The link is given below:
https://downloadcenter.intel.com/
I am assuming that you are using an Acer Aspire 3600 and you are looking for VGA driver. It is available for download on the Acer website on ATI or Intel vendors.
Just click the link below and then choose your Operating System. All the drivers needed for your device is available there. Just click the download link beside each driver.
http://www.driverscape.com/manufacturers/acer/laptops-desktops/acer/11075
