How to install driver wireless per acer aspire ao software?
Dear Techyv members. I'm wondering how to install driver wireless per Acer aspire ao software effectively without errors. Please give me a step by step process for this and kindly give me an overview of the driver as well as its key features and configuration. I would really appreciate it. Thank you for your help.
Best Answer by Huffman Serafin
Answered By 0 points N/A #152377
Hi Ross,
Go to this site  Acer Support.
Select your location.
Go to DRIVERS and MANUALS tab.
Under GROUP click Netbook, Chromebook.
Click Aspire One under Series.
Select  your type of product. ( You can find it at the back of your netbook.)
Choose your operating system.
You will see the list of available drivers.
Note: You may find many different drivers like Intel, Broadcom, Atheros. You must download the specific wireless card of your device.
Answered By 0 points N/A #152378
Hi Ross Suominen,
I am installing drivers after installing an Operating System on it in this way, I switched on another unit of the computer, I will Google this key word "<product name and model number> drivers download" and hit enter, afterwards, look at the series of result in google and choose the website of your manufacturer that is available for download, note that these searched drivers are compatible and is intended for that model number. Enjoy and install it clean.
