How to install a DSN for MS Access in Windows 7-32 bit?
Hello Friends,
How can I install a DSN for Microsoft Access in Windows 7 32 bit?
I have a MacBook Pro which utilizing boot camp. I have windows 7 and I installed MS Access 2007 on my windows 7. All things were going all right. On the other hand when I attempt to add a DSN, it did not work. It Send me an error message and stating that DSN does not equal or match. There is an architecture disparity stuck between the driver and the application
I have also installed both access engine 2007 and 2010. At this time what is the solution?
Thank you.
Error Found:
The specified DSN contains an architecture mismatch between the driver and the application.
