How to install Dual boot Linux Fedora 13 on Pc ?
please tell me step by step guide, How to Install Dual boot Linux Fedora 13 on a computer with Windows 7 already installed.?
There are different ways you can install Fedora 13 on a windows 7 PC and create duel boot. You can do it with either current MBR (Master Boot Recorder) where you can overwrite the existing MBR or you can do it on the Linux partition where it marked as Active.
If you want to follow the process where you want to use your current MBR you can follow the following process
http://thpc.info/dual/win7/dualboot_win7+fedora13_grub_mbr_on_win7.html
Else if you want to follow where you want to use a new partition then you can follow
http://thpc.info/dual/win7/dualboot_win7+fedora13_grub_lnx_on_win7.html
