jaycepierce
10 points
Posted on - 12/18/2012
I love to explore new features and its features.
The latest software which attracted me is the easy bus software.
Please tell me how to install easy bus software.
I also want to know whether I can install all at a time or individually.
I am looking for your kind help.
Thanks in advance!
How to install easy bus software
Before you download and install the software, make sure that it runs in your operating system.
Currently, the EasyBus requires processor of 1GHz and runs on a Windows XP, Vista and Windows 7.
Now here's how to install the EasyBus software.
Create two directories. Name the first file as Download and the other file as EasyBus.
Download the file or files of your EasyBus application. It should be in a '.zip' file. Save the file or files in the Download folder.
Unzip the files and extract it to the EasyBus folder. Take note, you should extract BOTH of the zip files and put it on the same folder location which is the EasyBus.
On the EasyBus folder, look for setup.exe file. Click it to start the installation in your system.
Instructions on the screen will appear and just follow the instructions to get your EasyBus software running.
I suggest that you should not install it all at the same time if you are referring to different EasyBus software.
Each tool has a specific function and it would be difficult to identify which file installed successfully or which file has failed.
It is best to install one at time so that you can pay attention on the instructions and how to do about the installation process. Aside from this, if you try to install ALL at the same time, installation time will be longer and there's no guarantee that it will all be successful.
Taylor
