Hello Experts,
How to install eee note apps? I would like to download and install many applications but I think it is only limited. Can you give me some tips and advice on how to deal with this eee note applications so that I would be more knowledgeable on using it?
Thank you.
There are some reasons why a certain application program cannot be installed in your eee note. Have you tried checking the downloaded file you want to install? Some have encountered problems like you and had found out that the file they downloaded was not complete, hence can't be installed.
Check also if the SD is supported and recognized and can be open when connected to the computer. If it all works, make sure that  dvt_check file is in the root of your SD card.
If the problems is still there, reboot it otherwise contact the supplier or manufacturer.
Regards,Â
Diane
