How to install the extensions for dreamweaver cs5? Is there just a such a named standard extensions and where can I find them? Will the Installing an existing extension help me to get the tools for working with my own extensions? Thank you for your help!
Hi Marvin M Calderon,
To install extensions for Dreamweaver CS5 just follow the steps below.
1. Download the Extension Manager CS5 installer.
2. Run the installer.
3. Once Adobe Extension Manager is installed, return to Adobe Exchange and then download the extensions from the
Dreamweaver Exchange. The extension have their respective download links, description, ratings, reviews.
4. When the Extension Manager has been installed, it can be accessed by clicking Help -> Manage Extensions, it can also be done by running the Extension Manager.
Hope this helps you.
Thanks
Installing an existing extension introduces you to some of the tools that you need to work with in your own extensions.
Download and install the Adobe Extension Manager, http://www.adobe.com/go/downloads.
Log on to the Adobe Exchange website at http://www.adobe.com/go/exchange.
From the available extensions, select one that you want to use and download that.
Save the extension package in the Dreamweaver/Downloaded Extensions folder of your installed Dreamweaver folder.
In the Extension Manager, select File then Install Extension. Dreamweaver: select Commands then Manage Extensions to start the Extension Manager.
The Extension Manager automatically installs the extension from the Downloaded Extensions folder into Dreamweaver.
Thanks for asking
