How to install floating chatbox website html?
Hi fellows,
I want to ask few questions regarding on how to install floating chat box website html? I am new in this html webpage thing and I want to learn more this kind of programming language as well as the PHP connected to this. Can you give me the step by step process of the installation to avoid errors? I am using windows 7 operating system.
Thank you.
Answered By 10 points N/A #181212
The floating chat box is a very useful tool in websites. You can design it on a website using html. You just need to add the code for the chat box in the website design. You can place the chat box wherever you want on the webpage.
If you want to minimize the chat box, you can do so. If a user has to use the chat box they can press the restore button and then again they can minimize it. The size of the chat box can be varied according to your use. You can also limit the number of users using the chat box at a time. All you need to do is create the code for the chat box and insert it in the website design.
You can get the html code for chat box here –
It is the code for a basic chat box. You can modify the code according to your requirement.
