playing game is very enjoyable, how do you install game software in apple desktop?
Rony Tin
5 points
How to install game software in apple desktop?
1.First insert your game CD into your Macintosh's CD drive(see the picture)
2.Locate the game icon (They will be clearly labeled , and they will usually have a .app extension).
3. Double click the installer to launch it or drag the game application to your Applications folder.
4.Follow the installer directions in the dialog box which  shown on your screen .
5. You will have  the  game icon in Applications folder after installation is completed.
6. Leave game CD in the disk drive. But if the game requires it in order to run. some of games doesn’t  run if the original CD isn’t  still in the computer.
