How to install games on Samsung B8300 ?
Dear Pierce,
Your Samsung B8300 is basically a Java phone. I.e. All the Java games with the extension ". jar" can be installed and play on your cell phone.
For downloading and installing games to your cell phone, you can:
Either go on gprs (through your cell phone) and look for games around on a lot of websites (by visiting websites through your cell phone). There are some common websites like https://www.funmaza.in/ , getjar.com where you can easily find games for your cell phone. But be sure to download games with only ".jar" extension as only those games would work properly on your cell phone.
As downloading games through gprs would charge you a bit so the other alternative to save up money would be to download games to your computer directly from the internet and then transferring the games from your computer to your cell phone (through Bluetooth or using datacable)
Once the game is downloaded/transferred to your cell phone, then you just have to open that up in your cell phone (the installation will be carried out itself and game would launch in a couple of seconds) 🙂
I can’t find an easy link that point directly to Samsung B8300. It either directs me to a printer with the same model number, or to another Samsung Smartphone, and so on. If you are sure that your phone is a java-enabled handset, then below are the websites where you can download different java games.
The best way to download and install java games on your handset is to visit the site with a computer and then download the games you want. All java games are in the form of “jar” archives or files. All game files you’ll be downloading from the site have the “.jar” extension. After downloading the files, connect your handset to your computer and simply copy them to your device. If your handset requires an application to transfer files, run your phone’s software then begin copying the files to your phone and then install them. Or from within your phone’s software, right-click on the game file then select Install.
I never thought that I could install any games on my Samsung! It’s truly amazing. I love playing games on mobile. On my mobile, all games were played and finished. So I wanted to get more games and here I got my help. After reading this page, I understood that I can get more games on my Phone from the internet. Then I got about hundreds of games on my mobile. For this, I really want to thank Sharath for helping me most. He helped me find out the easiest way by providing a step-by-step process and he also gave the links where I can download more games in my mobile phone. I am really grateful to him. Thanks a lot, Sharath. Also thanks a lot to Techyv.com for publishing this post.
