Emaily Rawa
10 points
Posted on - 05/28/2013
I used to backup the system partition on my computer using ghost software, and I have backups of ghost win me through win XP ready to be restored, I have to keep the system partition as it is, but when the partition size changes I fail, how to create a backup image that can be restored to any partition size and get it in an easy to install CD?
How to install ghost win me /2000 /XP from bootable CD?
Hi dear,
Thanks for asking the question.
I have a good solution of your question.
Here is cute PDF writer.its install itself like a printer.
Here is some requirements for installation.microsoft window me/2000/2003.
Ghost installer is very powerful application for your system.i am giving you a link just click on this http://softwaretopic.informer.com/create-windows-xp-ghost-bootable-cd/
You will find solution of your question easily.
I hope you will like it.
Hi Emaily Rawa,
I would like to tell you not to use other software in backing up files from your computer, I recommend you to stick on windows own backup function that is located on the control panel. To back the files up, you have to go to control panel and then select backup and restore, You can also burn it into the CD right away. This will solve your partition problem.
