How To Install Global VPN Client Mac In Simple Steps
Hi. I want to know about Global VPN client Mac. What are the steps to install it? It is really urgent so please ASAP. Thanks in advance.
Hi. To install Global VPN client Mac, first log in to the portal of GlobalProtect and open the web browser. On the web browser, enter the website acme.com after which a portal login page will appear. On the page, enter your username and password credentials and then log in to the network. Next, download the agent by clicking on the link of Mac 32 or 64-bit GP agent. Run the software and open the GP setup wizard. Next, using the GP installer install the agent by clicking on continue on the GP installer. The location for the installation can be changed as well.
Enter your credentials to install the software successfully and then click on close. After the agent installs successfully, log in to GP and enter your credentials required for the log in. The IP of the portal will be required as well. To log in, click on apply. You will be connected to the corporate network after the authentication is successful.
Hope we helped.
