How to install globe broadband driver windows 7?
Hi techyv,
How to install globe broadband driver windows 7? Those broadband connections will not run in a specific unit if the drivers are not installed properly. What is the best and proper way of installation of drivers to make it perfectly working? I really need my internet connection back.
Hoping for your help.
Best Answer by Smith Thompson
Answered By 0 points N/A #164963
Hello Janet,
It would be easy for you to follow this steps for you to install you broadband as well as your internet.
  1. Plug your broadband kit to your pc/laptop
  2. Wait until it scans your device
  3. Wait for a second a message will appear
  4. Install it and wait it to be done
  5. An autorun will start the modem as well as the connecting logo will appear
That’s all you need to do, thank you for more question please be free to ask it here.
Answered By 10 points N/A #164964
You don't need to install drivers for broadband internet as it’s a plug and play device and you just need to configure it by assigning an IP address to the network it is easy and you will be able to connect through the network.
Plug your broadband cable to the computer and double click on the blinking computer icon on the right most corner of the screen. Open network and sharing center and go to local area connection. Then set the IP for your computer as asked by your service provider and as I shown here.
Smith Thompson
