How to install google translate language package? And one more thing , can I download an offline version for google translate language package which I can download in my android mobile phone? Give some suggestion experts.
Google translate package is absolutely free and can be downloaded from most of the software sites online. The translate package allows you to translate web-pages, electronic mail and other documents without opening online-translation sites and buying expensive bulky programs. The software for the pc can be downloaded from http://download.cnet.com/Client-for-Google-Translate/3000-2279_4-10920739.html
If you use Google Chrome, you don’t need to install an extension for Google Translate because it is readily available in the browser. To access and use Google Translate, start Google Chrome then click on the “Google apps” icon next to “Images” on the upper right corner of the screen and then select “Translate.”
1....
