How To Install A Graphics Card With Different Methods?
I am a Garmin lover. I want to take gaming to a next level and improve the performance of gaming. How to install a Graphics card?
It helps in improving the performance of gaming and take it to the next level.
Method 1:
Step 1: Before installing the new graphics driver, you need to uninstall the old one.
Step 2: Power down your computer and detach power cable.
Step 3: Remove screws to open the case.
Step 4: Location of PCIe slot is close to the processor. There you can find expansion slot.
Step 5: Be careful in removing an old card and then put the new one. Do not damage it.
Method 2-
Step 1: When you open the case then take this opportunity to clean it.
Step 2: Without touching the contacts of the graphic card and only holding it from the edges, place it.
Step 3: Make the secure connections to prevent damage.
Step 4: Connect power connectors of card with power supply with the help of PCIe connectors.
Step 5: Close the case. Plugin the monitor and install the new drivers.
