How To Install HP Support Assistant- Steps To Follow.
One of my friends has come across a term HP Support Assistant. What is it? How does it help us? How to install install HP Support Assistant?
 It is a software program. It help us in keeping our computer in working order. Problem resolving is quick and easy through it.
Step 1: Go to Windows, search and open HP Support Assistant.
Step 2: To open My devices Windows, click Next.
Step 3: You will get two options. One is My PC and other is Add a device.
Step 4: PC box will show your details such as computer name, product number, etc.
Step 5: When you click on category tab then you will see information such as troubleshooting.
Step 6: Select Add a device box that detects new device on your computer.
