How To Install HyperTerminal Windows 7 64 Bit?
I want to install hyper terminal on my Windows 7 PC. Is there any way to download and install the same? Please provide me steps for how to install HyperTerminal Windows 7 64 bit.
To install hyper terminal, you need to download it from the link provided.
https://www.hilgraeve.com/support/htpe7.exe
You can install it to your system by Double-clicking the file that will be downloaded.
HyperTerminal is an alternative terminal that can help you to connect through various networks like Dial-up Modem, COM ports or TCP/IP networks. You can use it for various networking purposes. They are made for efficient usage.
If you want to use HyperTerminal, sadly, it is not included in Windows 7 and higher. Anyway, you can try these alternatives. First option is the Windows Remote Shell command line. It is available on Windows 7, Windows 8.x, and Windows 10. To explore the different options available in Windows Remote Shell, run the following command in the command prompt:
winrs /?
The Windows Remote Shell or the WINRS command is basically an SSH replacement which allows remote command line access over an encrypted connection. It uses the SOAP protocol. Second option is HTPE or HyperTerminal Private Edition. This one is not free software. This is a commercial terminal emulation program that allows you to communicate with serial COM ports, TCP/IP networks, and dial-up modems.
If you need one good HyperTerminal program, you can try this one out. HyperTerminal Private Edition costs $64.99. It supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. Tera Term is another option. It is an open-source terminal emulator and SSH module that supports the following:
Notifications
