How to install internet in my new blackberry phone?
I have connected my blackberry 8300 into my Facebook account, there's no problem about that, but i want to connect it in my yahoo mail or other internet services.
How can I install it? Or do I have to download it?
What things do I need?
Do I need any connector?
Best Answer by arafat hossain
Answered By 0 points N/A #115352
Hi Dear,
You can easily set up BlackBerry Internet service to use below instruction
  1. From the home screen select the “Email Setting/Internet Mail Account’ icon (which you found your setup folder).
  2. Read the terms and condition.
  3. Select “I Accept”
  4. Select domain for email address adds.
  5. Then put your email and password and click “Next”
  6. Then repeat the above step to setup additional email address.
  7. If you also like to create a free BlackBerry email address, then select “Create New Address” and follow the instruction.
Best of luck
Answered By 0 points N/A #115353
Solution
Hello Mr. Zanderp
I read your problem. But I Think this is not a very critical problem. Now I try to give some workable solution for your problem.
Please read the below solution and work step by step then I think you will cover up the problem.
You can easily set up Internet Service in your Black Berry set just follow these below instructions.
  • First select the Email setting or Internet mail account icon {where you found your setup option},
  • Read out the term and condition,
  • Select ‘I agree’,
  • Select domain for email address adds,
  • Then put your email and password,
  • Then press ‘Next’.
If you want to set up another email address then repeat the above step again and then set up your another email. If you wish to create a free Black Berry email address, then select ‘Create new address’ and follow the instruction.
Hope  your problem has been solved by these solutions.
Thanks from
Arafat hossain.
