How to install iOS 7.1.2 update on iPad?
I've heard that a bug fix update from Apple (iOS 7.1.2) has been rolled out for its devices. Can I install it on my iPad? Does it contain new features? How do I install the new version? Do I need a computer to install the update? Thanks in advance for the help!
Answered By 0 points N/A #199862
Yes you can install it on your ipad. Some bugs are fixed on iOS 7.1.2 and this is the most important of update files. You do not need a computer to install new version of iOS 7.1.2.
To install iOS 7.1.2 follow below steps :
(Before update your iOS you should be connected to the internet)
Follow steps:
1. Open Settings
2. Go to the General section
3. Software Update
4. Choose the available update then Download it. ( it takes from some minutes to some hours , depending on your internet connection speed )
5. When download has finished, Go to the Settings
6. General
7. Software Update then Install now.
