How to install iPhone browser on Windows 7
I want to know about the installation procedure of iphone browser on windows 7.How can I download windows and from which site?currently I am using iphone s4.Plz help.
Hello Anam,
Using iPhone Browser lets you duplicate files from or to Windows on iPhone. It is an open source software, which means it can be download freely in different websites. You can download the latest compatible account of this software. The installation is forthright, same as other standard Windows programs. When installed, attach your iPhone via USB and open the application (iPhoneBrowser) from the Programs. You’ll then see the iPhone wallet which you can now modify items anytime you want.
Here are some iPhoneBrowser system requirements:
-Windows XP / Vista 32-bit / Windows 7 RC 32-bit
-Microsoft .Net Framework 2.0
-afc2 service installed on phone (if none, iPhoneBrowser will not show all files)
>This is typically mounted as part of jailbreaking
-iTunes latest version and started with iPhone attached
