temptechy
Posted on - 11/18/2012
Hello Experts,
I am running MAC OS X Snow Leopard. Is there a way to get and install Java SE Development Kit 7 to my computer?
I am having trouble of where I can download and install it to my computer.
How to install Java SE Development Kit 7 for Snow Leopard?
Hello there,
Yes, there is way to get and install Java SE Development Kit 7 for MAC OS X Snow Leopard.
Apple has released Java SE Development Kit 7 for MAC OS X Snow Leopard.
You can download and install from here: https://support.apple.com/downloads
Before installing the Java SE Development Kit, your OS X must be updated. Otherwise, you may face some unexpected behavior with the installer.
You can find the guideline to install the Java SE Development Kit here:
http://www.oracle.com/technetwork/java/javase/downloads/jdk-7-netbeans-install-433844.html
Thank You. Hope it will solve your problem.
