How to install jdk in linux
I have a problem,I want to run java development kit in my linux operating system.The problem is that I don't know how to compile program in linux as is there in windows
First, Download the required jdk-7u<version>-linux-x64.tar.gz from https://docs.oracle.com/javase/7/docs/webnotes/install/linux/linux-jdk.html site. If you are trying to install on a normal Linux other than rpm based Linux then you need to follow the below steps.
Step 1-> Go the directory where you have downloaded.
Step 2-> provide this command to untar the tar ball
tar –zvxf jdk-7u<version>-linux-x64.tar.gz
Step 3->Delete the jdk-7u<version>-linux-x64.tar.gz file (for saving the disk space)
That’s it you have installed the jdk in the current directory.
Installing on RPM based Linux :
Once downloading is completed.
Step 1-> Go the directory where RPM is placed.
Step 2-> execute the below command
rpm –ivh jdk-7u<version>-linux-i586.rpm
That’s it installation is done. No need to reboot
Notifications
