How To Install Juniper Network Connect- Steps To Follow.
One of my friends has come across a term Juniper Network. What is it? How is it helpful to the user? How to install juniper network connect?
Juniper Networks is an American multinational corporation. It provides high performance network solutions to help the user.
Step 1: Uninstall the old version of Juniper Network Connect.
Step 2: Find Computer and select Organise then Folders and go to search option.
Step 3: Click on View tab which is under Hidden files and folders, allow Show hidden files, folders, and drives and press OK.
Step 4: Go to Computer, select Local Disk (C:) then Users and then "Click on your username".
Step 5: Delete the Juniper Networks folder by clicking on AppData folder and then Roaming.
Step 6: Install the Juniper Networks software.
Notifications
