How to install Legacy Sentinel Drivers in windows 7
I have used Legacy Sentinel Drivers in Windows 2000 and XP. Now I want to use it in Windows 7. Is it compatible with Windows 7? If it is then I would like to know the process.Â
Hi Geraldine,
I believe I will be very much able to help you with the problem you suggested you are having. The Legacy Sentinel drivers can also be installed in the Win 7 Operating System only that they are mostly used with the Windows 2000, Windows XP and Win NT.
The Legacy Sentinel drivers are very important for providing most efficient security will be found and downloaded from the website;Â http://softdeluxe.com/Sentinel-Protection-Installer-211068/. After downloading the software from the website, you will need to unzip the installer;
Click next to move to the licensing screen.
 When you click next, it will move to the setup screen.
You can then begin the installation;
Click finish;
It will be ready to go, I hope this solves your query.
