How to install lightscribe repository on ubuntu OS
Is there a guide that will help you install the base Lightscribe software and the 4L Disk repository Labeling software on a 32-bit or 64-bit Ubuntu install?
Hi
You wanted to learn about base Lightscribe software installation in ubuntu os. You also wanted to have a guidance on 4L Disk repository Labeling software installation and use. It seems that you are not that much used to the normal installation of such kinds of software. In ubuntu there is different process for installing software. But apart from these there is a little varied ways for installing above mentioned software. I tried on net and want to let you see the original article for the tutorial. Here is the link:
https://ubuntuforums.org/showthread.php?t=289922
Hope you understood that.
Notifications
