I bought my Nokia N8 in US and not I am in Italy. When I try to connect with Skype I get an ‘unable to connect to Skype server’ error, I think it is because of local Skype server problem. Am I right and If so how do I correct this error? Or is it because of something else?
This is a common problem but it can be solved. From the looks of it I can diagnose the problem as being a network problem. Most probably you phone was configured with the United States internet setting and therefore can not work in Italy.
These configurations can be changed either manually of a downloaded configuration file from your network operator. Contact you network operator for this.
It is not possible because Nokia N8 is a Symbian phone and Skype does not support it. Skype is available for Android and iOS. The Nokia N8 mobile phone is not an Android phone. It runs on Symbian. The Nokia N8 is a discontinued 3G Smartphone operating on 2G and 3G network bands using GSM and HSPA technologies.
Nokia N8
It was announced to the public on April 2010 and released on October 2010 measuring 113.5 x 59.1 x 12.9 millimeters and weighing 135 grams. It uses mini-SIM card. It has AMOLED capacitive touchscreen display with 16M colors at 360 x 640 pixels screen resolution. It supports multi-touch protected by Corning Gorilla Glass.
It runs on Symbian^3 mobile operating system upgradable to Nokia Belle Refresh powered by 680 MHz ARM 11 processor and Broadcom BCM2727 GPU. It supports microSD expandable up to 32 GB. It runs on 256 MB RAM with 16 GB internal storage and 512 MB ROM.
The primary camera supports 12 megapixels with 1/1.83″ sensor size featuring Carl Zeiss optics, Xenon flash, autofocus, face detection, geo-tagging, and ND filter. It supports 720p video recording at 25 fps and 720p at 30 fps (via SW update). It has a secondary VGA videocall camera.
It has 3.5-millimeter jack featuring active noise cancellation with dedicated mic support, Wi-Fi 802.11 b/g/n with UPnP technology support, Bluetooth 3.0 with A2DP support, GPS with A-GPS and Ovi Maps 3.0 support, stereo FM radio with RDS and FM transmitter support, and microUSB 2.0 with USB Host support. It has built-in accelerometer, proximity, and compass sensors.
The preinstalled web browser supports WAP 2.0/xHTML and HTML with Adobe Flash Lite support. Java is supported via MIDP 2.1. It runs on non-removable BL-4D Li-Ion 1200 mAh battery with standby time up to 390 hours on 2G and 400 hours on 3G. Talk time is up to 12 hours on 2G and 5 hours 50 minutes on 3G.
It is available in orange, pink, dark grey, silver white, bronze, green, and blue colors.
A Quiet Revolution in the World of Pages
Once upon a time every book left a trail. Bent spines dust jackets that never quite sat right paperbacks split at the seams. Shelves groaned under the...
1....
