jazzyjazz
Posted on - 02/01/2012
I have a question , I will soon obtain an iPhone using Verizon will our administrator need to install the software for Lotus Notes Traveler on our server previously to me installing Traveler Companion? I was informed I need to use Traveler to be able to push contacts, calendar and e-mails to an iPhone. My administrator is unfamiliar with the Iphone, so I informed my admin to do this. Is this correct way? Also is there any other possible way to do this?
How to install Lotus Notes to my iPhone
There is no direct way that you can install lotus notes to your iPhone.
However if you need the Lotus notes then there is way for it but you need to spend few bucks to make it work.
The notesPro app is a native lotus app and it costs 15 bucks for you from the app store.
iAnywhere is another app it is free but it requires some additional work to be done before setting it up.
iclink. This is the most expensive one.
However there is another alternative method for this which you can use as a secondary solution to this thing.
There is a trick from which you can use your Gmail in accordance with the lotus notes.
The complete guide is here.
