I want to install the Memories Disk Creator from HP. What are the step-by-step procedures on installing it?
What operating system is compatible with it?
Please send me some help and opinions from those who already tried Memories Disk Creator.
How to install memories disc creator version software?
Memories Disc Creator software is a good software to have fun with your photos.
You can create slideshows with music in it then burn it on a CD or print it if you like.
You can even put a title page in your work. There is a version for MAC and Windows depending on your operating system. It is sometimes pre-installed with some HP laptops and desktops but if not you can download it at the link (HP website) for free.
After you download the software, it will guide you on how to install it on your computer.
Follow these simple steps if you are installing it for the first time on your computer:
Go to this website
Click software and driver downloads
Select your OS and click on afsinst.exe and download it on your desktop.
Once downloaded, double click on the afsinst.exe icon on your desktop and click on upgrade.
Once installation is complete, restart your computer.
If the Audio File System driver had not been removed from your computer,
Download the driver, double click on the afsinst.exe icon and click overwrite.
Once the installation has completed, restart your computer to effect the changes made.
If the Audio File System driver has been deleted or removed,
Download the driver and double click on the afsinst.exe icon and click on install.
Once installed, restart your computer.
Best Regards,
Zeno
