How to install metatrader in hostgator
I install metatrader in hostgator, but it is not working correctly. Metatrader keeps giving me the error message. I try to fix the issue, but still I got error. Please help me how I remove this error?
Metatrader software download available as freeware in sunbierdfx install software click setup file and choose language in scrolling list of windows appeared after selecting language then press next then a window with copyright information displayed press next then license agreement window appears click checkbox as yes.
Then give path name or it automatically choose operating system drive path then click next then select metatrader in group then click next and again click next then installation starts and after it asks for launching then click checkbox finally select finish your installation done otherwise go to metatrader4 site then follow instructions carefully step by step and read specifications before installing
Hope these shall helps you
Thanks
