How to install Microsoft Office
Can I install MS Office on my computer even if there is already one installed? It is only because I need it opens a database that is created in 2003 version and I don’t want to overwrite the existing Office 2010. Can anyone please tell me what to do?
Answered By 0 points N/A #138574
Very simple. You have to install the software for the purpose. Dual version is possible if only the registry settings are kept different from the other. This system has to be used from behind. Means that once you install office to the machine, you can install the updates that are only required. This system needs a completely different installation. You have to choose a fresh installation at the install page. This is visible only if such a thing is possible for the software you are using. Else you install in a different OS and use the drivers from that OS for this OS. Means dual OS system.
