How To Install Microsoft Outlook 2010 With The Different Methods?
I need to use my email account frequently. How can I manage the emails and send them quickly? How to install Microsoft Outlook 2010?
Microsoft Outlook is useful in organizing and managing the emails that are from the web browser interface. It helps in sending the emails and receiving them quickly.
Method 1: Configure your Gmail account
Step 1: Select gear icon after signing in into Gmail account and then settings.
Step 2: Select Forwarding and POP /IMAP tab and then Save Changes.
Step 3: Click Accounts from the Tools menu and then Add.
Step 4: Type the information such as Server, Port, etc.
Step 5: Type your account information.
Method 2: Configuring your Hotmail account.
Step 1: Outlook Connector is free, download it.
Step 2: Select File tab and then Add Account.
Step 3: Enter the account information then click Next, and now you can use Outlook.
If you want to use Microsoft Office Outlook as email client to receive email messages, you need to have either the IMAP or POP settings of your email account. You can get it from your mail service provider. For Yahoo Mail accounts, here are the correct IMAP and POP server settings. For IMAP server settings, make sure you have the following configurations entered in Microsoft Office Outlook.
For POP server settings, make sure you have the following configurations entered in Microsoft Office Outlook.
IMAP is the ideal way of getting your email messages using an email client. It allows 2-way synchronization. This means everything you do remotely is reflected in your Yahoo Mail account. With POP, it simply downloads copies of your email messages. You can delete or move them in the email client without affecting the original email messages in your email account.
Microsoft Office Outlook is part of the Microsoft Office suite and can also be downloaded as a standalone application. Download Microsoft Office Outlook if you want to try it.
Notifications
