Greetings to all. May I ask how to install mini tabs Excel effectively? What are the steps needed for this kind of download? Is this easy to configure? I would also appreciate if you can give me a quick overview of the mini tabs excel so I can properly follow.Â
How to install mini tabs excel effectively?
I see that you need two programs to install: Minitab, software used to gather and analyze statistics, and Excel, spreadsheet software that is part of Microsoft Office.
To install, you need to either get a trial version or buy the software from their respective websites (here are the links for Minitab 16 and Office365).
The installation process is straightforward and you won't encounter problems as long as you can understand the instructions given.
