How to install a modem to the computer?
Installing a modem to a pc is an easy process. I assume that you are using a windows machine and you are the administrator of this machine.
1. Go to control panel in your computer.
2. Now go to phone and modem options. Select Modem.
3. On it, click "add". You will be getting a new installation wizard and then follow the instructions accordingly. Now accordingly add all the details in the wizard and you will be done. After the installation is complete, if you feel a little uneasy about it, then restart both the modem and the computer and then it will definitely work.
Hi Rizwanmohammed,
It's a little bit difficult to install a modem but you can try these steps and hope it can help you:
1. Go to the icons in the right side of your computer.
2. Then click the Network and Sharing System.
3. Click Set-up a new connection or network.
4. Connect to the internet.
5. Click next.
6. Click Set-up a new connection.
7. Then find the modem model, if ever it is not listed, try to check, "no, create a new connection".
8. Then click next, follow the instruction and in the last option, click "Finish".
9. Try your modem and if there is still problem, just click diagnose, and wait for the system's recommendation.Â
Here are the steps to install modem to the computer. There are 2 ways, either by using USB or via Ethernet cord (cat5) connected to from modem to your computer.
For Ethernet cord type of connection:
* Your computer must have Ethernet adapter installed:
* Once identified that you have Ethernet adapter installed.
* You may connect a cat5 cord from modem to your computer.
* This should let you connect to the Internet automatically.
For USB type of connection:
* Connect a USB cord from modem to your computer.
* Insert the USB CD/Disk drive to your CD Rom.
* It will either auto-run the disk then follow the instructions to install the driver.
* If it will not run automatically the installation, you may follow the steps below;
These are the steps to install modem to your computer.
Hope this helps.
