How to install netware repairs?
I am having a problem on installation. How to install netware repairs?I need the right procedure for the installation so that it will perfectly go through. Need some help.
Thanks
Thanks
To repair netware, sometimes you'll need to install netware service packs. They are called Netware Repairs. To install such repairs you may follow following process:
Dear Acke Zimri,
Hope to be well.
The best way to setup the program is by going to control panel and then go to add / remove programs and then choose (Add new program).
This u r l should be helpful:
https://technet.microsoft.com/en-us/library/bb742421.aspx
This way leads to good installation of the method.
Hope that to be helpful.
Best regard,
Don Muench
Super suggestions from all of you guys. I will especially mention Debra Labito because the information and step-by-step process shared was very easy and crucial. You are right; sometimes we need to install Netware service packs to repair Netware. Reading your solution made me sense on how I will install it and I have determined that this is the right procedure for the installation. It will be perfect for me to go through. After installing,I am not facing any problem anymore. Thank you and to techyv.com for helping me by providing those vital information.
