navia21
20 points
Posted on - 10/02/2012
Greetings to all,
I download the oDesk setup into and was wondering how I could install into my laptop. The image or the icon of the oDesk setup is color greenest. Maybe you guys are familiar with it. Is it ready for installation or do I need something else to install this set up.
Thank You.
How to install oDesk setup into my laptop?
You did not point out the purpose of the software. There are many types-team, screenshots, timer and many more. If you want to set up the software for team you should use the offline setup version rather than the online version. It generally facilitates as virtual office working system for easy teamwork.
Check this link.
1. Download oDesk time tracker here –
Click the Download Now button, then choose Save file. In the download manager window, double-click(or right click and choose Run exe) the exe file, as seen in the image below:
2. A window will prompt you(see image below); click Run
3. In the oDesk Team Setup, click Install, and wait until a window will prompt you with Installation complete message(see image link below).
4. Click on the Launch oDesk button in the down-right corner. A window requiring your login details will appear. Enter your login data and click Sign in(see image)
Done. You can now select your team and start working.
Good Luck.
It is very simple just follow below steps:
1) Go to https://www.odesk.com/downloads
2) Select your OS from right side. (If it is Windows then click yellow Windows Tab).
3) It will ask you to save location, select your saved location, and it will start downloading automatically.
It's so simple.
If you want to download the oDesk Team software, just go here.
And then click the Download Now button on the right side if you are using Windows PC. Else, select the Mac OS X or Linux links if you are using any of it. Once the downloading process is done, you can see the green icon as shown below:
Double-click this icon to run the oDesk setup and start the installation. Click Install to accept the oDesk Team License Agreement.
When the installation is done, click the Launch oDesk Team to start the program.
