How to install opera mini on nokia c5
I would like to install opera mini for my Nokia c5-03 but I don't know how and I don't know which opera I should download I need step by step instructions on this.
As we all know that Opera Mini is the best mobile browser supported by a number of mobile phones on different platforms. You have already mentioned that you are using Nokia C5-03. Your device supports Opera Mini 4.4, Opera Mini 7, and Opera Mobile 12.
You can get all the versions supported by your device here,
The versions mentioned above are recommended for your Nokia C5-03, but, if you want to check other versions of Opera Mini then please visit the following link,
You can choose any version of Opera Mini there and just click the “View download link” and you will get the download link for that corresponding version of Opera Mini. Simply download the application on your computer and then transfer the setup file to your phone. Install the application and enjoy browsing internet with the most popular mobile browser on your Nokia C5-03.
I hope you will find the information useful. Happy browsing.
Browse through the menu of your device.
There you will see the OVI store icon. Simply launch this application by either touching it or by clicking the middle button. After that, login into it. If you have not signed up for this, then the first step is to sign up for the OVI store using a valid email address.
Once signed up, you can now login to your account. There you will see a list of applications. Just browse through them or enter the Opera Mini in the search bar. It will automatically find the opera for you. Download it and install. You can also try this link if it’s possible for you.
Go to mobile software downloading sites like mobango, zedge, mobile9, so on the select the model and search for opera mini new version and just download and install it, it take few minutes for installing the browser.
The recommended version for Nokia C5-03 is Opera Mini 4.4, Opera Mini 7, Opera Mobile 12.
Download above software in your computer and then connect your mobile to the computer and transfer opera browser into your mobile. Install browser in your mobile.
Dear,
First of all go to your web browser from your Nokia c5-03. Then log in this site. Then click "Download Opera for phones and tablets". After load this page click " download Opera Mini." After click this option Opera Mini will be download. After complete download you can use Opera Mini easily. Please use internet setting to connect Opera Mini.
Nokia C5-03 has a Wi-Fi so it is possible to download Opera Mini directly from your mobile phone. Just simply go to m.opera.com to download it using your phone's browser or you can go to Opera Mobile to download it.
