How To Install Oracle Java In SuSE
SuSE have openJDK and openJRE by default, however, these two won't seem to work every time and seems to be lacking features Oracle Java has. How can I install Oracle Java (JDK and JRE) in OpenSuSe? Will it get replaced automatically after install or should I configure it first?
Answered By 0 points N/A #108996
Hi Bryan,
It will install java in the following location:
/opt/java/32/
or
/opt/java/64/.
Followed this guide to create the package: Oracle (Sun) Java for openSUSE and Fedora – Easy Linux tips project.
The package will download and install jre and java plugin and will add new entries in "update-alternatives" and set the oracle-java as default java. It adds update-alternatives entries for, java and javaws.
It also links libnpjp2.so from /usr/lib/browser-plugins/javaplugin.so for mozilla plugin.
It should also remove those entries (except for the soft link for java plugin) while uninstalling.
you can find the package "oracle-java-installer" here: Index of /reporitions/home:/wildnux/openSUSE 12.1
