How to install pc doctor recovery in Windows XP?
Greetings Techyv members. I accidentally deleted some of my project files. Is there a way to retrieve this? I'm researching about Pc doctor recovery, is this any good in terms of data recovery? I need an honest, and comprehensive answer toward this matter. Also, include a step by step process on how to do this.
Best Answer by Burton Studebaker
Answered By 0 points N/A #135531
Recovering files after you accidentally delete it is like living again after death. Especially when these files are really important. It’s a good thing that there are many data recovery software that we can choose from in the market.
As you know, the PC Data Doctor Recovery is one of them. The PC Data Doctor Recovery is powerful software that can recover not only accidentally deleted data but also all the corrupted data’s due to crashes. It has better rating than the other data recovery software so I believed you are on the right track of recovering your files.
Here is a link where you can watch the video tutorial on how to do it:
http://data-doctor-recovery-ntfs.software.informer.com/
Answered By 0 points N/A #135532
Hello there Roman,
Yes, you can get back your files. Try this first:
Click on Start, go to computer, then select c drive
Right click c drive and select previous versions. Now, select an earlier local disk date and double click to open it.
Then select users and find your account. There you will find pictures, documents, videos, and whatever you need. Once you have found the file that you need to drag and drop it to the desktop.
If this did not work, download the PC Doctor that I will recommend for you to use.
This is called KingSoft PC Doctor. The step-by-step instruction can also be found on the same page prior on how to install.
I hope this information helps you.
Good luck!
Answered By 0 points N/A #135533
There are many ways to recover your deleted files, PC Doctor is one of the strongest tools to recover lost files or data.
First check your recycle bin if you found just double click and restore it to your originating location.
Otherwise you can download free recovery software
Some recovery software are as follows:
  1. PC tools file recover
  2. Restoration
  3. Panda recovery
  4. UN delete plus
