How to install php cms templates with control panel capabilities?
What are the steps on installing PHP CMS Templates with Control Panel on my site? Is there anything that I should download first in order to achieve this? What are the benefits of installing it and how can I merge and insert it on my webpage?
Answered By 0 points N/A #137743
Installing CMS template will allow you to make attractive and easy- to- use Flash websites. It comes along with a control panel which allows you to easily change and customize your website with no additional software required. Another good thing about the CMS template is that you don’t have to be an expert to fully understand it. To install it, refer to the link below:
https://support.motocms.com/hc/en-us/articles/203590500-Installation
