How to install pogo games for Mac? The pogo games are ready now for I have downloaded some from the internet; I want your help regarding the installation process. I would also like to know who invented pogo games?
Virginia Adams.
galib
Hi Jacklyn Andree, I searched a solution that may help you solve your problem.
First you identify your Mac operating system. If it is any version prior to Mac OS X 10.4.8, you cannot use Pogo with your Mac. Next Click the Apple on the upper left side of the screen, select "System Update" and finally, "Update Now." Follow on-screen instructions to either install or update your Java for Mac program.
Clear your Internet browser and Java cache regularly to prevent temporary Internet files from causing System Out of Memory Errors. Clear your browser cache by clicking "Empty Cache" from the upper left corner of the Safari main menu. Clear your Java cache by accessing Java Preferences via the Spotlight search bar. Type "Java Preferences" in the search bar, select the “Top Hit” — or Java Preferences — and when the preferences window opens, select “Delete Files” from the Temporary Internet Files section — the bottom section of the window. Click "Save" and exit the Java Preferences window.
Use Pogo only when playing games online. You cannot use the downloadable versions of Pogo games on a Mac and play your game.
Galib
