How to install a premiere avi codec?
Hello fellows,
How to install a premiere avi codec? My adobe premiere software application seems need an avi codec and I think it will really make some improvement on the built in features in the adobe application. Can you share with me the idea of proper installation?
Chloe Chylly.
Answered By 0 points N/A #179032
Avi codec is used by a movie player, flash player and other adobe products. There is vast number of avi codec installer in the internet. But if I were you, I’d rather install the VLC or the Video Lan Coded program or application, because it has an avi codec that it can share automatically on all programs after the installation of this application. Try to install also the K-lite codec; it will install all the different kinds of codec.
