Dear Techyv members, I'm currently looking for a way how to install print monitoring system software in my laptop. How can I make this possible? Are there any issues or errors that can occur upon its installation? If so, how can I address this issue if ever. Please give me a step by step guide for this.
How to install print monitoring system software?
After installing your Printer Monitor you can use the INF file on your installed printer device. You need to install the language monitor first by adding the LanguageMonitor to INF DDInstall section that can be found in the INF file this will display the name of the language monitor and the name of the DLL. Second you need to install the port monitor to do this you need to open the printer folder that can be found in the control panel. In the printer folder on the "File" menu, choose the "server properties". In the dialog box that will appear select the "Port" then select the "Add Port" another dialog box will appear, select the "new port type" the type the INF file in the text box and press "OK".
