jojy marry
Posted on - 06/26/2013
Hi. I am a new convert to the Mac world, my son and some friends are avid Mac users. I have had my iMac almost a year, just after my PC blew up! Everything downloaded was fine with no asking for passwords or codes. But, the error message says it won't install Print Shop without Art CD. Then when I try installing the print shop art CD it says application not found. Please post if I have to burn these onto a CD first or not. I do not want to sound like a complainer, but why is there this huge gap in quality graphics software?
How to install the print shop art cd
Print Shop really needs the Image Disk or also called as Art Disk and this is required to be on DVD disk.
This is the right way to install the Print Shop 23.1. Follow these instructions for better result:
Step 1: Install the Print Shop 23.1 to your DVD drive.
Step 2: From the list of installer, choose "Modify" then hit "Next"
Step 3: In the left part of the Content hit the button and choose to install on local hard drive.
Step 4: In the left part of the Program disk hit the button and choose to installed in the local hard drive.
Step 5: In the left part of the Art Disk hit the button and choose the installed in the local hard drive.
Step 6: Hit "Next" then "Install"
Step 7: You will see a prompt that you need to follow for you to finish the installation.
Step 8: When the installation is already finished, you can now use The Print Shop 23.1
