Dear Techyv members, I'm going to ask how to install program game with Scilab successfully? What are the steps needed to make this a possibility ? Please include an overview of the program as well as its key features. I would also like to know about its pros and cons.
How to install program game with scilab successfully?
Hello Samantha,
Scilab is mainly used for mathematical computations. It’s like excel for Linux but with a bit of SPSS. It is rich in data types, integrated graphics and it has a large library. However, it has a poor user-interface and it only supports static libraries.
To install Scilab,
· Download it from their website
· Save the file to your desktop and extract by right clicking the saved file. you could also use this syntax if you are using Terminal $HOME/Desktop/ ; tar xzvf scilab-5.1.bin.linux-i686.tar.gz
· To launch the program, you have two options:
1. Run this [$SHELL] cd <scilab-path>/scilab-5.3.3
[$SHELL] ./bin/scilab
2. Go to Application>>edit menus>>education>>new item>>type “scilab”>>command “/opt/scilab-version”>>comment “matrix scientific software. A dialog box appears. Copy the scilab.xpm icon to the navigation bar. You can then start scilab under /application/education/scilab.
Expert
Hi Samantha,
Scilab is a software package used for numerical computations that provides a complex computing setting for engineers and for scientific purpose. It is an open source software, which makes it a good alternative to more expensive computing softwares.
To install Scilab you can check on this link for a detailed step by step instruction for Linux and this link for Windows.
The requirements for Scilab to run successfully are:
OS (32 and 64 bits) : Redhat, Fedora, Debian, Suse, Ubuntu.
: Windows XP, Vista, 7, 8
: Mac OS Leopard, Snow Leopard, Lion, Mountain Lion
Pentium III or equivalent / Mac Intel 64 bits
2 Go RAM or a minimum of 1 Go
550 Mo HDD space
Firstly, I saw topics like 'How to put in manually a software system …' however my drawback does not solved!
I've downloaded Scilab five.4.1 from official web site. and that i extract '.tar.gz' come in :
/home/scilab-5.4.1
directory. I tried below commands but get several errors:
$ cd scalib-5.4.1
$ configure @1
$ make @2
$ make install @3
Termianl Messages :
@1: configure: command not found
@2: make: * No targets specified and no makefile found. Stop.
@3: make: * No rule to make target `install'. Stop.
I tried following Terminal-Command to run that :
$ cd scilab-5.4.1
$ cd bin
$ scilab
Termianl message:
The program 'scilab' is currently not installed. You can install it by typing: sudo apt-get install scilab
Thank's
