Hello friends,
How to install resident evil 5 windows mobile? I just downloaded a resident evil 5 for my windows mobile phone and it seems like I have to follow some important instruction or guide on the process. I want to install it successfully to avoid some problem in my mobile phone.
Thanks and Regards,
Kristin Runaldou.
The way to install the game depend of the file format :
1) The file format is "cab"
– Connect your phone to your computer and make sure the synchronisation software is ready to use (two software can be used which are ActiveSync or Windows Mobile Device Center)
– Open the sync software
– Browse for the cab file and drag drop it after clicking on the explore button. The file will be copied.
– Then using File explorer, locate the CAB file and tap on the CAB file to begin the installation manually
– Follow the instruction to complete the installation
Without Synchronisation software
– Transfer the CAB file from your computer to your device. Steps 4 to 7 describe using ActiveSync® to do this from a PC, but other synchronisation software is similar to this.
2) The file format is EXE
– Connect your phone to your computer using a USB cable then double click on the .exe file and follow instruction to install the game.
There are two versions of game files that you can install on your Windows Mobile. If you downloaded the CAB file of the game please follow the below instructions.
* Always check whether the game supports your Windows OS version on your phone before downloading.
1. Connect the data cable and sync your phone to the PC using "Windows Mobile Device Center" application which is installed in your PC. If you don't have the application just connect the phone and select "Data Storage".
2. Open your "files and folders" and copy paste the CAB file in any folder.
3. Now from your phone browse the file you copied and click on it and "allow" the application to get installed to your device. After the installation you can find the game installed in programs.
If you downloaded the EXE version please follow the below instructions.
1. Sync your phone using the "Windows Mobile Device Center". You must have this application installed on your PC in order to precede the installation.
2. After the sync is completed run the EXE file on PC and you'll get a pop-up on your phone display asking access. "Allow" the application and after the installation you can play the game by opening it from "Programs" in your phone.
