How to install rhapsody player on Ubuntu?
How to install rhapsody player on Ubuntu or do I have to just satisfy myself with web Rhapsody only? I have tried it but not have been successful .
Hello Jaycelin
Rhapsody player is indeed a very great application to manage your audio and video files. But as of now, it is not available for Linux or Mac. Its only available for Windows. If you still want to give it a try by using some illegal methods, check this URL https://ubuntuforums.org/showthread.php?t=497711. This may help you some bit.
Hope this helps.
Happy Computing 🙂
-Jack Hostler
You need to install Rhapsody plugin in versions above FF 1.0.1 and before FF 2.0 (or Swiftfox 2.0), then the plugin will be ready for you to use online at Rhapsody.com.
Download FF 1.5  and run it, go to Rhapsody.com, search for your favorite artist, click the link to play a song.
After getting pop up, select Yes, then close your browser.
The plugin will be installed in Firefox directory.
